12-11-2004 11:51 PM
12-13-2004 02:42 PM
12-13-2004 05:13 PM
@LoganS wrote:
Hi KL,
The Read Meas.vi is one of the subvi's in the App. Example.vi, so this problem is most likely the same problem in each case. From the help for Read Meas.vi:
Data Storage instructs the device to store the data to be sent to either the internal or external buffer. If TRUE (default), the VI stores data in the on mode. If FALSE, the VI does not retain data in the off mode. Use the off mode only with the average min/max operation when you do not need to retrieve data. You cannot configure the meter for external buffering in the off mode.
So the question is, are you trying to retrieve any data? If so, then as indicated in the above paragraph, you cannot retrieve data and have the data storage turned off. Good luck!
Logan S.
12-14-2004 01:46 PM
