03-09-2010 06:31 AM
I'm using LabVIEW 2009 and have installed NI device drivers(NI-488.2).I've connected HP 83752A synthesized sweeper to the PC through GPIB cable.The GPIB address of this instrument is automatically showing up in the VISA open function.The problem is in the Agilent I/O connection expert,under Instrument I/O on this PC this instrument address is showing up with a Failed symbolbefore it saying there was a communication failure.Even If I send *IDN? string I'm getting "There was a communication failurae as response".can any one help me out
03-09-2010 06:44 AM
03-09-2010 07:03 AM
thank you fo your reply.can you please tell me what to do in Max
03-09-2010 07:12 AM - edited 03-09-2010 07:13 AM
To do what? Just communicate to the instrument? If so, right click on the instrument listed there and select 'Communicate with Instrument'? You can also select Tools>NI-VISA>VISA Interactive Control.
p.s. Going to the Help menu is also a good idea.
Edit - you must also install NI-VISA.
