HP Agilent 34970A with LW
Hi, my name's Fabrizio Crestani.
I have acquired the data logger, but it doesn't function with LW in
serial RS232 mode.
I have corrected the errors wich concern the files of end string CR
(0x0D) with LF (0x0A). Now, the program runs correctly but it reads
random values.
The native HP-Agilent program of data logger runs correctly by RS232.
My configuration in LW is 115K N,8,1 XON-XOFF.
I have tested the driver hp and ni, but both don't function.
Could you help me?
Buying a card GP-IB PCI NI: does 778032-51 change into anything?
Thanks.
Fabrizio Crestani
Fabrizio "Sky" Crestani
Universita' degli Studi di Trento
Facolta' di SS.MM.FF.NN.
crestani@science.unitn.it
defence@tin.it
ICQ 43800167
http://www.compa.3000.it
We are Borg: Resistance is futile; strenght is irrilevant;
death is irrilevant; your life, as it has been, is over" >
(3,165 Views)
I've got a lot of these instruments and have never had a problem programming
them but I'm using gpib and LabVIEW. If it's a LabWindows problem you're
having, you should post to the LW newsgroup.
Fabrizio Crestani wrote:
>>Hi, my name's Fabrizio Crestani.>I have acquired the data logger, but it
doesn't function with LW in >serial RS232 mode.>I have corrected the errors
wich concern the files of end string CR >(0x0D) with LF (0x0A). Now, the
program runs correctly but it reads >random values.>The native HP-Agilent
program of data logger runs correctly by RS232.>My configuration in LW is
115K N,8,1 XON-XOFF.>I have tested the driver hp and ni, but both don't function.>>Could
you help me?>Buying a card GP-IB PCI NI: does 778032-51 change i
nto anything?>>Thanks.>>
Fabrizio Crestani>-->Fabrizio "Sky" Crestani>Universita' degli Studi di
Trento>Facolta' di SS.MM.FF.NN.>>crestani@science.unitn.it>defence@tin.it>ICQ
43800167>http://www.compa.3000.it> >< " We are Borg: Resistance is futile;
strenght is irrilevant;> death is irrilevant; your life, as it has been,
is over" >
(3,165 Views)
Fabrizio Crestani wrote in message
news:MPG.141881a7b087bdc3989684@newsgroups.ni.com...
> serial RS232 mode.
> random values.
> Could you help me?
> Thanks.
> Fabrizio Crestani
to
> defence@tin.it
> ICQ 43800167
> < " We are Borg: Resistance is futile; strenght is irrilevant;
(3,165 Views)
