HP/Agilent 8657 RF Generator VI drivers
Hello
I want to use HP/Agilent 8657 RF Generator in my measurements set-up and got  VI drivers for this equipment from NI library.
This VI is very simple: only frequency and output power may be changed. There are not options for changing of modulation types (FM/AM), external/internal input, index modulation and others. My question: is additional drivers for this type RF Generator with more functions?
Thanks in Advance for your assistance
(3,135 Views)
(3,039 Views)
Hi
I got drivers for HP/Agilent 8657 RF Generator from this link and there are RF power and frequency options only .
Thanks for your efforts
(3,024 Views)
Accepted by topic author Leo_T
try to modify it by yourself
bhovhann
(2,997 Views)
The driver for N5181A has the 8657 listed as being supported and has more functionality than the 8657 driver. It will install as Agilent PSG MXG Series.
Edit: The HP8257 is listed, not the HP8657. Sometimes a newer model driver will work but I don't see the 8657 listed.
(2,973 Views)
OK,
Thanks for your advising.
I will try  to run this driver.
(2,947 Views)
