HP Basic Equivalent in LabView
Hi all!
I want to write a Labview driver for the HP 5371A "Frequency and Time
Interval Analyzer". I'm looking for the equivalent for the following lines
to get data from the instrument written in HP Basic:
TRIGGER Counter
FOR I=1 to Sample_Size
ENTER Counter USING "%,K"; Meas_a$(I)
PRINT I, Meas_a$(I)
NEXT I
It's not clear to me how to implement the ENTER Statement in Labview. The
VI_GPIB_Read doesn't work.
Can anybody give me some hint or even send me a short VI?
Many thanks!
Stefan
(3,694 Views)
It has been a vry long time since I worked with HP Basic but a GPIB
Read should work with instrument assuming that there's data in the
buffer, you have the correct address, the instrument's connected, and
you're using a NI GPIB card. Have you tried something simple like
writing IDN? and then doing a read? Does the instrument show up in MAX
and can you communicate with it there?
I would also suggest that you use VISA instead of the traditional GPIB
functions. They give you some more flexibility.
(3,694 Views)
Stefan,
Did you ever get that issue resolved?
Can you please post or email a copy of the vi so I can take a look at the implementation
Larry
(1,936 Views)
@LarryJunek wrote:
Stefan,
You are asking in an ancient stale thread about a user that had not visited the forum in 18 years. I strongly recommend to start a new thread and explain what problem you are trying to solve. Communicating with an instrument is typically trivial.
(1,909 Views)
