The difference between your serial VIs and mine is that you used VISA serial VIs but I used directly the serial port VIs from "Instrument I/O" in "Funtions". The basic theory of your VIs and mine is same, both about the communication via serial port. Neither I used the command "*IND?" nor the command to hp34970a, cannot the VI run correctly. The error code was still -1073807339, "Timeout expired before operation completed". I wonder if the commands for hp34970a, which I got from "Instrument Drivers", would be right. I attach the photo to show the command for temperature measurement and hope you would give me advice.
Thanks a lot.
