HP3885A with GPIB interface
I'm trying to develope a program under Labview 7.1 to acquire the spectrum  from the HP3885A with GPIB interface.  Does anyone have the driver or example vi for HP3885A?
Waymon
(2,674 Views)
Is the HP3885A an IVI compliant instrument?  Can you use an IVI driver with it?  Even if there isn't one available, or if no users respond with a driver, you could use the IVI Class drivers, if it is classified as an IVI device.  Also, have you submitted a request a driver?
Logan S.
(2,657 Views)
