HP6002A Driver
It has been a while since I used these VI's can you give me more information like do you get an error? what version of Labview are you using? Does the instrument show up in MAX?
Message 11 of 13
(729 Views)
Hi Phil,
I trying to work with the HP6002A with no success too.
Some GPIB controller special configuration? I am using the USB-GPIB-HS and LabVIEW 8.6.
I believe MAX should not work with the HP6002A because it has no commands implemented. In my case, MAX find interuments in all GPIB address, but no answer to the *IDN? query.
Thank you
Message 12 of 13
(596 Views)
I believe the 6002A power supply does not work on the SCPI based command set so it will most likely not respond to the IDN command. I did find a manual of the device that has some information regarding the programming. Unfortunately I no longer have access to that power supply.
Message 13 of 13
(587 Views)
