HP7284A VI.
I need a VI for an HP4284A precision LCR meter. I have the drivers for the above but can not find a VI that has on it's front panel; BIAS: and the ON/OFF switch for the DC Bias. I have found a VI that has; FUNC:, FREQ:, LEVEL:, RANGE:, and INTEG:. The previous is how these quanities appear on the LCR meter. I am using LabView 5.1/Windows 98/GPIB. I have just finished Labview Basics 1 & 2 and have very little prior experience with Labview. Any help will be appreciated, Thanks.
(2,639 Views)
If you have the same driver I have you should find the HP428x DC bias level.vi
Easiest way to check is to load the whole llb and use ctrl-F to find for the text "bias" in all vi's
greetings from the Netherlands
(2,639 Views)
