HP8757 Scalar Analyzer control
Having some struggles with getting some drivers together for the HP8757.  Have both the C, D and E version.  Generally when you query the instrument, there is typically a question mark (?) at the end of the query string.  To get the number of points that the 8757 is set up in, it indicates that command is simply "OPSP" - no question mark in sight.  I can't seem to write that with a VISA Write, as it hangs the bus up.  Tried a Read, with same result.  I'll then need to read back that number.  When I do Write the "OPSP" string, I get a display on the 8757's screen indicating it's sending data to the GPIB, but I get back an Error Code and I have to Preset the instrument to clear the bus.
(3,328 Views)
All those links to a duplicate post are just irritating.
(3,317 Views)
What links?  I did not put any links in my post.
(3,304 Views)
