HR2000+ Outputs Multiple Intensities Per Wavelength (LabView 2021)
I'm having issues with my UV-Vis spectra output from an Ocean Optics HR2000+ through LabView 2021 (Windows 11 computer).  When my spectra are output in Excel, I get integer wavelengths with multiple copies per wavelength, e.g.
Wavelength      Intensity
199                   720
199                   760
199                   680
199                   700
200                   915
200                   902
I believe the wavelengths are supposed to read as doubles with nonzero decimals but I can't find where the integer form is coming from. I increased decimal points displayed in Excel and all wavelengths read ###.00000000, so it's not a question of display but a rounding/casting issue somewhere.  I have checked the sub-VIs for take spectral waveform and calculate wavelength from pixel number, both treat wavelength/pixel as doubles.  Where should I be looking to make sure the wavelength gets passed into Excel as a double with nonzero decimal?  Thanks!
(1,928 Views)
It is most likely rounding when you export to spreadsheet / Excel. But, you have to post your code for anyone to know for sure.
(1,914 Views)
My bad, here it is.  The UV-Vis spectra are also super messy, although I'm not sure if that's related (instead of a smooth curve, vertical whiskers along the entire length - looks more like a seismograph that got hooked up to a blender than a UV-Vis spectrum)
(1,884 Views)
Accepted by topic author JuliaGUIUC
When you convert the the DBL to a string you are using "Number to Decimal String". The name is a bit confusing, but if you look at the output it gives you a "decimal integer string".
You want to use "Number to Fractional String" for non-integer values.
(1,851 Views)
