HTML column alignment
We create a summary data sheet in html format. In the first section there is
Model:  value
SN value
HW rev value
In the second section there is
TEST DATA
Tes1 value
Test2 value
Third section:
Date: value
Time: value
Etc: value
On the screen the columns look fine but when printed the 2nd section values are left shifted as shown here. All sections have column widths set to 2.5 inches. Any suggestions?
jvh
(3,353 Views)
Update:
I measured the hard copy and in the 2nd section the 2nd column starts at 2.5 inches. The others were about 2.8 inches.
Strangely (to me at least) setting the width for all columns to 2 inches caused them all to align.
(3,344 Views)
Accepted by topic author jvh75021
column width defines the width of each column in the report table. The value you enter must be in inches or centimeters, depending on the settings you enter in measurement system for column width. The default is 1. For HTML reports, the VI multiplies the value by 100 to set the column width in pixels.
Note  If you set column width to a large value and send several columns of data to the VI, the VI automatically resizes the column width to fit the width of the report on a single page.
(3,333 Views)
