HTML to PDF Using ActiveX
Dear Expects,
                        I am using the PDCreater for HTML to PDF Conversion. PDFCreater have ActiveX Contol. but i am access the PDFCreater in LabVIEW some function is not working.
Please some one help me, how can i change the AutoSave file Directory using ActiveX.
Here i am attaching the LabVIEW code this method is correct or not?
(3,706 Views)
I don't understand the logic of what you are trying to do, but anytime code doesn't do what you expect, the first place to start looking is at any errors that are being generated - which you aren't collecting or displaying...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,692 Views)
I'm usingBullzip PDF Printer to create a PDF. It is possible to set Filname and path programatically via ActiveX.
Works good!
(3,668 Views)
