HTTP CLIENT : OPEN HANDLE
Hi all,
i'm using the http open handle and this cookie file as shown in the capture but when i build an exeand run it in a other machine  it doesn't work anymore and i tried application directory also , what fonctions should i use
any help please
(2,982 Views)
When you said you execute on another machine it doesn't work, is there an error coming up? If so what is the error? How did you configured the application directory?
Thanks & Regards,
(2,942 Views)
