HTTP Client - Failed to Load Library (Ubuntu only, fine under Windows)
Hello
Few years later, did you find the solution to this issue? I have the same problem. My code run well using on a virtual machine having the full Labview environment installed, but not on a machine with only labview run time. Both virtual machine have OpenSuse 15.2 distribution.
So I guess some library are installed while installing labview and not when installing inly run time
Message 11 of 14
(1,069 Views)
To be honest, I'm not quite sure whether I managed to solve the issue or bypass it. I think it was either reinstalling all the libraries on the Ubuntu system (the build system, not the production one) or using different VI's instead.
Message 12 of 14
(1,059 Views)
In the end we installed run time engine 2021 (we were using 2020) and now everything work like a charm
anyway, thanks for the feedback!
Message 13 of 14
(1,017 Views)
Hi, when I switched from OpenSUSE to Ubuntu, I had the same problem and discovered that with the operation
sudo apt autoremove
Ubuntu removed the "ni-ssl-bin" and "nissli" packages.
Reinstalling them with
sudo apt install ni-ssl-bin nissli
HTTP Get calls started working again.
Alberto
Message 14 of 14
(422 Views)
