HTTP Client VIs not working on RT Target
I am trying run to get_HTTP (Get.vi) on an RT target (cRIO-9014, LabVIEW 2011 version) to access a webpage on a Linux machine. I am getting the error as given below: (It works fine when I run this on my Windows machine).
Error 7 occurred at Call Library Function Node in LabVIEWHTTPClient.lvlib:GET.vi->get_HTTP.vi
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
HTTP client VIs (Get, Post, PUt , etc.) are supported on RT targets? Is there any workaround to fix this problem?
Appreciate your input......
(4,490 Views)
Hello Vasudevks,
The error you are receiving is due to not having HTTP support installed on your real-time target.  You can install that software using Measurement & Automation Explorer.  We have made a note of this and will be updating the error code to be more specific.
Mike Altmann
Product R&D
NI
(4,368 Views)
As of LabVIEW 2015 it appears this Error Message has not been updated to be sufficiently specific.  It still gives a general error that a file is missing.
(4,185 Views)
same problem with Crio 9066.
(4,049 Views)
