HTTP POST and GET Requests with LabVIEW
All,
What i'm trying to achieve is reproducing the XML-RPC protocol in LabVIEW (this is an extremely simple protocol ontop of HTTP.) If anyone can give me an example of sending an HTTP post and/or get request in LabVIEW i'd love to see it. Any help is appreciated.
Ken
(7,411 Views)
This is too simple to make an example.
Use TCP/IP Open to open a connection.
Use TCP/IP Write to write the request.
Use TCP/IP Read to read the data.
Look at the TCP/IP examples for details.
Put the TCP/IP Read in a while loop, until you get an error (probably
"connection closed by peer" or something). Put "Connection: close" in the
HTTP Post header, so the connection will be closed by the server.
Wiebe.
(7,393 Views)
I was wondering if anyone succeeded in communicating in XMLRPC through a TCP/IP connection in labview?
thanks in advance
(7,351 Views)
I am currently developing an XML/RPC client for LabVIEW.
(7,269 Views)
It would be great if you could let me know if you succeed en send me some information/you're program/client.
thanks in advance,
Karel
(7,257 Views)
