HTTPS Certificate CA Information of the local host is invalid
I am working to connect to a website setup by our IT staff, which uses a self signed certificate.  Originally this website was developed using standard http (for internal access), but they want to move to https now.
Since I am using LV 2018 and 2020, I need to update the ca-bundle.crt in order to be able to access the site, since the Certification Authority is not in the bundle.
I have looked at this knowledge base, and updated my local ca-bundle.crt.
I got the .CER and a .p7b (Contains Root and Issuing Certificates) from the server, and copied the within those files from the
-----BEGIN CERTIFICATE-----
<base 64 encoded values>
-----END CERTIFICATE-----
into the C:\Program Files (x86)\National Instruments\Shared\nicurl\ca-bundle.crt.
I no longer get the Error 363507: LabVIEW could not verify the authenticity of the server.
The new error I get is as shown below (Error 363506):
My existing deployed code does not have the ConfigSSL vi in it, where I could point to a new certificate, so I am trying to figure out a way to update the ca-bundle.crt.
Any thoughts on what could be the issue?   My google skills on that error have failed me.
Kenny
(2,601 Views)
Accepted by topic author Kenny_K
I was able to solve the issue.
I downloaded the Cacerts.pem from Mozilla: https://github.com/gisle/mozilla-ca/blob/master/lib/Mozilla/CA/cacert.pem
I then extracted the .pfx file from my IT department into a .pem.
I copied the contents of the .pem from my IT into the cacerts.pem.
I copied the cacerts.pem into the C:\Program Files (x86)\National Instruments\Shared\nicurl and renamed the cacerts.pem to ca-bundle.crt to match what LabVIEW is expecting.
This allows me to query the internal HTTPS without issue, and the existing code does not need to be updated.
Kenny
(2,577 Views)
