HTV and data logger closing program.
I am using Labview 6.1 with DSC. I am currently having problems operating my data logger and HTV. I have my data logger set up programatically as well as calling my HTV programatically. First of all, I have upgraded the logos file to the latest version (4.0.14), and have set the time server IP for my fieldpoint modules to the correct host computer (FP 1601's). However, sometimes when I try to export my data during certain times, I recieve and error which reads, "Labview.exe has generated errors and will be closed by Windows. You will need to restart the program." This is a program error, so the engine does not stop. However, it does not occur all of the time. Also, it occurs sometimes when I try to enter the HTV. When this do
es work, the data will log and save to a spreadsheet correctly. When I call the program back up it will work, but it is as if the program running for a while creates some sort of fault condition in windows.
(3,627 Views)
I had problems recently using the HTV. The DSC update fixed it. If you have not loaded the fixes you can find a link in my answer found here;
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=50650000000500000012B60000&HTHREAD=000046610&UCATEGORY_0=_51_%24_6_&UCATEGORY_S=0
I hope this helps,
Ben
(3,627 Views)
