Handle one case with different type sources in Event Structure
System:
LabVIEW 2014
Windows 10
Hello, I am struggling on a simple problem which is triggering an event structure with different event sources, for which I could not find an answer in the forum . I want to run a piece of code either when I press a button or when I press a specific key: the spacebar.
In the attached VI I am able to do one or the other (where I use the ScanCode of the key spacebar to trigger a case with the code I want to run), but when I try to combine the two, I receive this error
I have already checked that it is simple to have multisource event with the same type (e.g. two Booleans or two key downs) but I am sure there must be an simple solution for this, since this seems like a very common situation.
I would appreciate very much any help you guys could send my way, thanks!
PS: I leave a Disable structure so that the code can compile without considering the problem.
Message 1 of 16
(2,088 Views)
Hi rpicazof,
simple solution: use two event cases!
Place the common code in a subVI (in both events) or in a case structure after the event structure...
Message 2 of 16
(2,082 Views)
I would consider the easiest solution is put whatever code is inside the event structure in a subVI, and just have two different event cases that both call that subVI.
Message 3 of 16
(2,081 Views)
Hi GerdW and RavensFan,
thank you very much for the quick response! Definitely what you suggest would work, but I discarded this idea since the code I want to implement is absolutely humongous and embedded in a very dense front panel that I don’t want to detach. It seems strange that event structure cannot handle this situation… I was wondering if using some kind of  “variant” would do the trick, but I could not figure it out.
Message 4 of 16
(2,041 Views)
If you want to keep the code in one event case, there are two possible solutions:
  • Have the code in the button value change event and create a second event for the key up event. Place a proberty node "Value(Signaling)" into that event, and wire a TRUE to it. This way, whenever the space bar is pressed, a click on the button is simulated, which will also trigger the event structure. This only works when the button is a latch, and the button event shoult reset its value back to False.
    This is quick and dirty, but works.
  • Create a user event, register for it, and wire it to the UserEvent Terminal of the event structure. You will then get a new type of event, where you place your code.
    Then, create an event for the button as well as for the key, which both will generate such an event.
Message 5 of 16
(2,034 Views)
This is an indication of bad design. No code should be allowed to be humongous.
Anyway, you can put your code in a third event that you can trigger programmatically.
The quick-and-dirty way in those cases is to add a hidden boolean control and use its Value (signaling) property to trigger its Value Change event.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 6 of 16
(2,032 Views)
Accepted by topic author rpicazof
If you right-click the button and go to "Key Navigation" you can set a key to toggle the button. You can't use spacebar, but you could use any of the function keys (F1-F12), Clear, Delete, End, Page up/down, etc.
You could also create an event case to handle the Space bar button press that toggles the Value Change (SIgnaling) event of your OK button (unless it's latching, in which case you can't have a Value Change (Signaling) property node)
Overall yes, one case can handle two events, BUT the events must return the exact same data. Since the "OK" button press event doesn't return a Scan Code value, it won't let you do that.
Consider this- what would you expect the value of Scan Code to be when you clicked the OK button instead of the keyboard? It would be undefined.
Message 7 of 16
(2,028 Views)
I would use a different key than the <space bar>.  That's too common a key to be using like that.  What if I am editing text and your application takes focus away from the editor and I hit the <space bar>?  Now, if you're thinking about how the Windows API makes a button in focus respond to the <space bar> as a "click", I do believe LabVIEW buttons with focus respond the same way by default.
Bill
CLD
(Mid-Level minion.)
Message 8 of 16
(2,018 Views)
Hello Sebastian.Weber ,
Thank for your response, could you send this snippet or VI file for the 2014 version? Many thanks!
Message 9 of 16
(2,014 Views)
You can also but a case structure after your Event structure, where you can put code required by more than one Event.
Message 10 of 16
(1,983 Views)
