Handling front panel buttons within an Event structure
Is there an easy way to handle front panel buttons inside an event structure? I'm currently using an event structure to pop up a settings tab, but I only can use  buttons that are designated as events. Is there a way to use non-event buttons to run a setup and calibration sequence inside of an event structure?
(2,301 Views)
Accepted by topic author AdamHZ
I'm not sure I understand your question. From what you describe you should look into a producer consumer architecture where your event loop receives an event then off-loads the work to be done to the consumer loop. This keeps your Event loop free to receive events. LabVIEW 2012 ships with a good example of this, the Queued Message Handler template project.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(2,297 Views)
I'll try that out
(2,281 Views)
