Hardware Clocking Error PCI-5122
I tried to run the vi attached (which i've run many times before) and my computer bluescreen.  When it rebooted, I could no longer use my PCI-5122 digitizer card.  When I try to do a device test or device reset in MAX, it tells me that theres a hardware clocking error..   I was using an external trigger for the aquisition, but don't think I was using an external reference clock.  Could someone help me fix this?
NI Hardware: PXI-7853R, PCI-5122, PCI-6733, PXI-1036, PCI-MIO-16E-4, PCI-6110
Computer Hardware: Xeon Quad Core - 2.33 Ghz, 8 GB RAM
Software: Labview 2009, Labview FPGA 2009, Vista 64-bit, MAX 4.6, DAQmx 9.0, NI-SCOPE 3.5
(4,186 Views)
Accepted by topic author noli
This error may be the result of a hardware failure where the only solution is a repair or replacement. There are however, some basic troubleshooting steps that have been known to correct this issue without a return.
  1. Reboot the PC or PXI controller.
  2. Try a different PCI or PXI slot.
  3. Update the driver to the latest version.
  4. If possible try the card on a different machine.
If these steps to not correct the issue then it is likely the board requires repair which can be arranged by contacting National Instruments Technical support (in france: 01 57 66 24 24).
Thomas B. | CLAD
National Instruments France
(4,143 Views)
Thanks.. yeah, after tryign all that without success, we're going to send it back
(4,141 Views)
