Hardware Timing 2
I have found a DAQ-STC VI that I plan on using called "Count Time Easy".
I do not know what to wire the string terminal to. Do I need to make a new
channel that specifically looks for the DAQ-STC? Or do I just make a string
constant and wire it in?
(2,899 Views)
Just make a constant string, either "0" or "1". It is looking for which
counter to use, and there are two. Specify which counter, either 0 or
1.
Mark
In article <39940e7e@newsgroups.ni.com>,
Easy".
a new
string
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,899 Views)
