Hardware closed loop control by compactrio
Hi Everyones,
I am trying to build a closed loop controller in LabView using CompactRio.
My project is to acquire 3 AI (analoge inputs NI 9215)) V1, V2 and F1 (two velocities and a force) from my hardware.
I need to acquire these three signals and make some math calculations on the V1,V2 and F1 then generate analog output (NI 9263) AO based on these values
I need to save data on disk
Is there a way to do that using FPGA and RT target? Or any tutorial that uses simple AI and generate AO FPGA on CompactRio
(2,680 Views)
you might want to start here
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,677 Views)
