Hardware driver programming : Help !!!
Hello
I just bought a special X-ray sensor, which came with its ISA interface card
but without any driver. The documentation indicates which registers and
memory range to read and write, and I have to build the LabView driver
myself. I need to program only some basic tasks (such as impose gain and
exposure time, start an acquisition and get back the data), and I planned to
call some C routines with Code Interface Nodes.
I don't have any experience in hardware programming, and I don't know which
C functions I must use to access the memory and registers to dialog with
this card.
Any information (book reference, example program ...) would be very
helpfull.
Thank you in advance.
Eric Hervieu
Commissariat a l'Energie Atomique - Grenoble
DTP/SETEX/LTDF
Tel : (33) 04 76 88 45 33
Fax : (33) 04 76 88 52 90
E.mail : eric.hervieu@cea.fr
(3,193 Views)
Hello Eric,
if you are using Windows 95 you can use the InPort/OutPort Functions of Labview
(you can find them in the advanced\memory menu) to do register-level programming.
I've devoloped an analog i/o-Driver for a Keithley DAS 1600 DAQ card in
that way. It works quite pretty. If you are interested, I can send you an
example VI via e-Mail.
Martin
"Eric Hervieu" wrote:
>Hello>>I just bought a special X-ray sensor, which came with its ISA interface
card>but without any driver. The documentation indicates which registers
and>memory range to read and write, and I have to build the LabView driver>myself.
I need to program only some basic tasks (such as impose gain and>exposure
time, start an acquisition and get back the data), and I planned to>ca
ll
some C routines with Code Interface Nodes.>>I don't have any experience in
hardware programming, and I don't know which>C functions I must use to access
the memory and registers to dialog with>this card.>>Any information (book
reference, example program ...) would be very>helpfull.>>Thank you in advance.>>Eric
Hervieu>>=============================================>Commissariat a l'Energie
Atomique - Grenoble>DTP/SETEX/LTDF>Tel : (33) 04 76 88 45 33>Fax : (33) 04
76 88 52 90>E.mail : eric.hervieu@cea.fr>==============================================>>>
(3,196 Views)
I too need to talk to an old Keithley DAS 20 (!) -- but inport/outport does not work on WinNt
due to memory protection! Any ideas?
Martin Eis wrote:
> Hello Eric,
> Martin
> time, start an acquisition and get back the data), and I planned to>call
(3,193 Views)
Helen,
Check out the KnowledgeBase article on accessing the parallel port from NT
(http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/c80752c53
094c296862565f3007ac765?OpenDocument). The llb and zip files at the bottom
of this article contain NT compatible In Port and Out Port vis. I'm using
them successfully on my NT.
Hope this helps.
Jim
Helen E. Kourous wrote in message
news:396B2186.986D51E0@erim-int.com...
> Martin Eis wrote:
> > Hello Eric,
Labview
programming.
an
> > Martin
interface
driver>myself.
and>exposure
in
access
(book
advance.>>Eric
l'Energie
04
(3,193 Views)
hai Martin,
I was also searching for the labview drivers for DAS 1600 card. Could you also post me the driver file to my email. Or give me some weblink where I can get the Labview drivers for Keithley DAS 1600 card. me email id
nandakishorenaidu@gmail.com
thanks in advance
nanda
(3,180 Views)
