Hardware triggered digital acquisition
I would like to measure frequency of rotation of an encoder after let's say bit number n of a known digita waveform is constant for 3 seconds. I assume I need to use counters to measure frequency but I don't know how I should use the trigger signal. Is there any example that can help me on this
(2,739 Views)
Hi tintin,
What kind of encoder are you trying to measure?
If the output is just a standard pulse train of varying frequency, you can use DAQmx functions to measure it.
Here's an example that will do just that.
https://decibel.ni.com/content/docs/DOC-13039
Good luck!
Josh E
National Instruments UK & Ireland
(2,701 Views)
