Hello PCKOST,
Thank you for contacting National Instruments. The most direct approach to this, using the "Key Down" or "Key Up" event in an event structure PDA application, is not supported by the module because these events correspond to QWERTY keyboard inputs.
It is possible that you may be able to access a DLL or something like that on the PocketPC itself, that will return event keystroke signals to the LV PDA application. I searched around on the PPC website, however, and could not find anything that would do this.
I will make a suggestion to our R&D team regarding the PDA keystroke functionality, because it does seem that it would be a useful feature. Thank you for your input!
Liz F
