Has anyone any experience with a USB-6008 and reading a thermistor value
Labview 8.0 connected to a USB-6008
I am using 'BC Components' NTC Thermistor. I used the express VI to create a Vex input and entered the A,B,& C values from the datasheet. The thermistor is the 10K version and I placed a 10K resistor in series with it. I wired it as is shown in the connection diagram, and applied 2.5 volts to it.
I get completly the wrong temperature readings out of it! I called the NI help line in the UK and the engineer confirmed that I had done everything correctly but couldn't understand why it didn't work.
Any thoughts?
Steve Lawson
(4,214 Views)
Hi Steve,
The only things I can come up with is to try using 4-Wire mode for the thermistor, or you could send in one of these thermistors to the UK office for us to look at.
Regards
JamesC
NIUK and Ireland
(4,182 Views)
I had a similar problem, had it working at one point then screwed it up.
try this:
(4,173 Views)
Here is the LV 8.0 version
(4,170 Views)
Thanks for the 'Temp Pressure EXpress80.vi' but it won't load because LV can't find the 'Convert thermistor reading.vi'. Either it is a VI that you wrote or it is part of LV8 that I haven't loaded.
I'll give it a try once I get it working.
I will also try the 4 wire mode before I send a device to NI.
Steve Lawson.
(4,150 Views)
Tryconfiguring it as a 2 wire Iex.
(4,143 Views)
I know that this thread is old but I ran into the exact same issue as the OP.  I found that the solution is to wire up the NTC Thermister to a differential channel, not SE channel.  Then it worked fine.  Apparently the measurement is a differential measurement and one of your differential inputs is probably floating, at least is was for me.
(3,300 Views)
