Most likely the 6508 card will not be fast enough to implement the SPDIF protocol. Even at slower rates SPDIF bit rates are in the MHz range, which will be too fast for this card.
One possible solution for SPDIF is the FPGA based
7831R reconfigurable I/O (RIO) card. Using the LabVIEW
FPGA module you can program the FPGA on the card for a wide range of applications including implementing digital communication protocols. The card has 96 DIO lines and the FPGA communicates directly with these lines.
Christian L
NI Consulting Services
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
