If you only want to capture data from your RS485 port, communicate through Datasockets.
or you can use a RS-485 to RS-232 converter and Address to a RS232 port, such as COM1, then you use VISA to communicate via RS232 using ASRL1::INSTR.
National Instruments sells RS485 board that that plugs into a PCI slot:
http://sine.ni.com/apps/we/nioc.vp?cid=1363〈=US
I hope this helps.
Regards~
Mathews
