Has anyone had success in installing Simulation Interface Toolkit on a 64 bit system?
I can install the Toolkit; however, the tools are not visibile and it does not link with MATLAB.  Does there  happen to be a special download for a 64 bit system?   If there is I can't find one.
(2,624 Views)
Accepted by topic author Koselke
At this time, the only version that SIT is compatible is LabVIEW 32-bit.  You can still run it on Windows 7 64-bit, but it must be the 32-bit version of LabVIEW in order to function properly.
(2,607 Views)
