Has anyone hd experience with laview and ge fanuc or allen bradley plc,s . I am looking for best combo
geranft,
The specific combo shouldn't be that big of a deal since more than likely you will be communicating to it through a defined protocol or basic DIO/AI/AO.  Normally, you will connect to a PLC through OPC.  In this case, the DSC module is the easiest way to interface with LabVIEW.
See the DevZone article below for much more information:
Craig D
(4,088 Views)
