Has anyone tried to use LabVIEW as a modbus slave with a PLC master?
Hello.  I use modbus extensively with PLCs as slaves.  I am finding that it might be benificial to make the PLCs be the master in my next application.  I have tried this with the MB Ethernet Example Slave.vi without any luck.  Can anyone help?
I am running LabVIEW 8.6 on Windows XP with AutomationDirect PLCs using ethernet communication.
Thank you in advance for your help.
Ron Deavers, CLD
(3,193 Views)
I think the following document will get you up and running. Ignore the RT target portion and replace it with the target as your computer:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFeECAW&l=en-US
FLash
(3,169 Views)
I forgot to mention that I do not have the IO Server addon module.  I know that this can be done with the modbus download from NI.  I have been unsuccessful as of yet so I thought someone has accomplished this already.
Ron Deavers, CLD
(3,153 Views)
Hi
There are two options to connect to a Modbus device. Either the Modbus IO Servers (found in the NI LabVIEW Datalogging and Supervisory Control Module) or the free Modbus Library.
FLAsh
(3,134 Views)
