Has anyone turned a .cdf to an .ipk?
I have been reading this page NI Linux Real-Time and opkg: Distributing Packages — nilrt-docs 1.0 documentation
But I don't see how this would work the same way installing with a cdf file would work?
Has anyone done something similar where they installed labview drivers, and an application release using .ipk format?
(418 Views)
VeriStand Engine is essentially a RTEXE built using LabVIEW. So if you install a VeriStand Engine IPK to a Linux RT target, you are installing a RTEXE.
https://tmesystems.net/
(370 Views)
