junka,
I have not used this solution, however I would assume that you should have no problem with this. Like most hardware devices, the ethernet card should be abstracted from the software by the hardware driver, so opening a TPC port or using shared variables should work assuming this ethernet device is recognized as a normal network connection by the PDA via the device's driver.
Message Edited by Doug M on 12-03-2006 10:32 PM
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me ๐
