Has anyone used a touch screen monitor with scxi.I am having video lock ups while using LV and MAX
I have a PCI-MIO-16XE-50 daq card (dev1) connected to a scxi-1000 chassis address 0 ID 1, with a scxi-1102,1163,1163,1162 slots 1,2,3,4 respectively.Cable is connected to daq card to 1102 card .Micro touch screen is used on com2. Have tried other serial ports 1,5. Touch screen works fine with windows until LabView and max is installed .Video lockups,Max failures occur.MAX seems to confict with touch screen.
(3,092 Views)
Max is the NI interface for all the drivers. It may be a specific driver that is causing problems, perhaps NI-VISA. I would try installing things one piece at a time. Might want to start by uninstalling everything so that you start with a clean system. First install LabVIEW with no drivers at all. See if the Micro touch screen still works. Then try installing NI-DAQ. Install each of the drivers you need one at a time. If you don't need something, leave it out.
(3,092 Views)
