Has anyone used native Windows ActiveX (like MSVidCtl) to bring in Live Video?
Hi All,
      Has anyone embedded a live [composit] video-source in LabVIEW using nothing more than a simple Windows-compatible video-capture card and some native-Windows activeX control on the front panel?  Sorry if there has been a previous discussion and answer about this - there are a lot of kinda-sorta (non-applicable) related posts that involve IMAQ, cameras and expensive video hardware.
I selected MSVidCtl for a Front-panel ActiveX container and its methods/properties look intruiging, but maybe it's useless.
Any help is appreciated,
Thanks/Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,144 Views)
well, MSVidCtl (in WinXP) seems to handle lots of picture/video-file types easily...
(still working on streaming/live video into this control...)
(3,129 Views)
Hi tbd,
This sounds like an interesting endevor.  I have not tried this and I am not sure how feasible it is. Good luck.
I looked around a bit, and I found this thread that talks about the Video for Windows API and includes and old, but apparently effective, example program. This may be a good starting  point.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,114 Views)
Hi Spex,
      Thanks!  Downloaded the [LV4 !] .zip, will check it out an report-back.
Cheers.
(3,081 Views)
