Has anyone used the waveOut interface in Labview to simultaneously output multiple wave files?
I am trying to do simultaneous output of wave files in LabView.  Play Sound only does one output at a time.
(2,731 Views)
Hello Caladan,
Are you referring to the waveOut functions in the Windows Multimedia API? If so, you can use the Call Library Function Node in LabVIEW to call the waveOut* functions (these functions come with winmm.dll). Just in case, here is a link to the documentation for them in msdn:
Also, here is an article on how to use waveOut interface to play wave files simultaneously that might be helpful: Playing multiple wave files continuously and simultaneously.
Good luck and let me know if you need help with the LabVIEW aspects of the issue.
Shakhina P.
(2,710 Views)
