Has anyone written a driver for the Labsphere SC-5500?
Correct.
You can run it twice when using the termination character \n and you can not run it at all without a termination character because it timesout.
Message 31 of 32
(628 Views)
Try communicating to it without using the IO assistant (which I never use).
Use the serial communication VI found in the example finder (Help menu > Find Examples).
Under the Search Tab, type "serial" and try the Advanced Serial Write & Read.  See if you have the same problem.
R
Message 32 of 32
(621 Views)
