Has anyone written an Import Waveform from Spreadsheet File?
It would be nice to have a vi that can read the files written by Export waveform to spreadsheet file. I realize this is a lot of work, but if you want to be able to use waveforms with a spreadsheet as well as with LabVIEW, the only alternative is to save it twice -- once using Export Waveform to Spreadsheet File and once using Save Waveform to File.
(7,252 Views)
this is simply a case of re-organising the data you're saving. You have the waveform Y array, and you need to append on the dt and t0. Then save this whole array.
Unpacking it is a case of doing it in reverse.
S.
// it takes almost no time to rate an answer Smiley Wink
(7,251 Views)
I also want to import a set of data from a spread sheet to create an arbitrary waveform as a drive source.
(7,003 Views)
What type of file are you having ? If it is .csv or .xls file, you can very well use the VI in the previous post.
Can you explain more of your actual requirement ?
- Partha ( CLD until Oct 2027 🙂 )
(6,993 Views)
I am very new to LabVIEW.  I am primarily a digital engineer with 37+ years of experience and some analog experience.  I started programming uPs in 1972 with the Intel 8008.
I thought that the previous post was for exporting the waveform only, now I have run it and I see that an import is also possible.  I don't quite understand it however.  Apparently the csv file data is Y values only with even steps of X determined somehow.
What I am looking for is the ability to create a spread sheet with X, Y pairs to describe the waveform.  What we are doing is hydraulic impulse testing.  What we need to raise a pressure over a short time, then decrease the pressure, then maybe raise the pressure again to a value, then hold the pressure steady for an extended time, then reduce the pressure back to 0.
Here is a very simple example spread sheet file.  I could easily export the two data columns to a CSV file, and I can organize the spread sheet in whatever way might be easier to work with in LabVIEW.
I appreciate the help.
(6,978 Views)
Hello Don,
Though I don't know how exactly you want to have this data be generated, you can import the data and change this into a waveform fairly simply.  I have attached a VI that opens a CSV file that will plot a waveform of the data.  It assumes that the data is whole numbers and does not linearly interpolate the data.  So the plot has a lot of points that increase or decrease in the period of 1 second.  Though this may not be the perfect code you need, this is a good basis for starting to get your data out and manipulate it.  If you have any questions, please let me know.
Brian Coalson
Software Engineer
(6,969 Views)
Hi Don,
Here is a better example that uses the interpolate function.  I adapted the Interpolate 1D array example.
Brian Coalson
Software Engineer
(6,948 Views)
