Have I possibility to start application created in LabVIEW on another PC without performing
LabVIEW installation procedure?
(2,493 Views)
Using application builder you can make your LabVIEW application standalone, or you can create a runtime engine (not sure if runtime engine can be downloaded from NI). In LV 5.0, you can create a runtime engine building an executable without embedding any llb. With runtime engine you can run a vi in a machine without LV installed.
Hope this helps
(2,493 Views)
