Have LabVIEW VIs been developed for use with the Omicron CM Engine dll? It is the software interface to the CMC-256 hardware, a 3-phase voltage and current source.
Hello Del,
I looked on Omicron's Site and they have not made an instrument driver for this as well as NI does not have a instrument driver posted. LabVIEW does allow you to talk to a dll through the call library node. Here is a link to get you started:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/a6705fec7ea42300862567b70054206e?OpenDocument
I hope this helps.
Doug
Message 2 of 8
(6,346 Views)
Where did you find that omicron CM engine dll??? i can´t find it anywhere..:(
Message 3 of 8
(6,346 Views)
...and have you done a controller vi in LabVIEW for Omicron CMC-256? or you perhaps know where to find it??
Message 4 of 8
(6,346 Views)
hii,
Where you able to solve the problem as I am facing the same problem, Can you help me....Smiley Happy
Message 5 of 8
(5,870 Views)
Hi All,
Here comes up with a new LabVIEW PnP driver for CMC-256. Hope it is not too late to help your projects.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=19083
Message 6 of 8
(4,975 Views)
Can somebody help me with link where I can download LabVIEW driver for OMICRON CMC256 Cm-Engin.
Thanks in advance
Message 7 of 8
(1,876 Views)
In the last message in this thread, before you revived it after 11 years, is a link to a driver that you can download. It is not using ghe Engine.dll but instead directly communicating through TCP/IP with the device but that has the advantage that all is fully in LabVIEW VIs and not hidden inside a DLL. Much easier to debug your application and less chance to crash your program.
Rolf Kalbermatter  My Blog
Message 8 of 8
(1,864 Views)
