05-18-2007 07:44 AM
05-18-2007 08:33 AM
Hi Richard,
As far as I know, put all the sub-VIs into the same folder where you keep your Main VI. This is the only way to make LV "look" for the sub-VIs in the same folder. But the first time you open your Main VI after doing this, it ll ask again for the sub-VIs to be linked up manually.
Otherwise, if you continue loading it without them, the Main VI ll show broken arrow. You ve to link all your sub-VIs manually which in turn, again ll be a tedious exercise. ![]()
Thats why I ve been maintaining all my sub-VIs in the same foldeer as that of the Main VI from the conception of my project. ![]()
Using same 7.1. ![]()
05-18-2007 09:15 AM
05-18-2007 10:21 AM
05-18-2007 10:29 AM
