Have to reintialize the string indicator value
Hello Everyone
I am trying to reintialize the string indicator value.
I am using the string indicator property node to change the color, its changing but when program reruns it has to start from default value how to make this one. Thanks in advance
(3,251 Views)
Can you post your code so that we can better help with what you are doing. It really depends on how you are using the string indicator as to how you would initilize it.
Tim
GHSP
(3,242 Views)
Righti click on indicator -> create -> invoke node -> reinitialize to default.  Put that invoke node at the beginning of your state machine.
Kudos and Accepted as Solution are welcome!
(3,239 Views)
hi
Thanks for the reply can you convert the VI to 2009 and post it
(3,234 Views)
Accepted by topic author Nandisha.BV
Here it is in 2009
(3,219 Views)
Thanks for the solution
(3,199 Views)
