Having AI and DI at the same time using DAQ assistant
I want to have data acquisition of some analog and digital ports using DAQ assistant, but it gives me error of "The specified resource is reserved". I was wondering if anybody knows how to do that using DAQ assistant.
Thanks.
(2,808 Views)
I suggest you to use DAQmx VIs, which give you more freedom in optimisation of code.
- HS
(2,798 Views)
Thanks.
I have not used DAQmx Vis. Do you know any good website/book that can help me? (unfortunately the examples are not clear enough for those who have not used the palette yet)
(2,789 Views)
hi,
this link can be of your use http://decibel.ni.com/content/docs/DOC-15408 .. just configure a little as per your need of AI ..
HS
(2,786 Views)
Thanks. I appreciate it.
Baran.
(2,784 Views)
Smiley Happy Kudos are good for appreciation ..
Any way if you need any further explanation of that VI please post here.
- HS
(2,780 Views)
Good to know. I was not familiar with the concept of Kudo. tnx.
(2,776 Views)
