Having issue with exe that looks for broken vis
hi Folks,
I wrote that basically looks for broken vis in a folder and reports them. it works great and does what i need it to. i made an exe to distribute it and built the exe. when i run the exe and ask it look at the folder containing the broken vis, it basically reports all the vis as broken even though there are many which arent broken. the exe and the VIs to look for are in different folders. I'm not sure why this is happening. your inputs are most appreciated!
Santosh
(3,559 Views)
How are you checking to see if the VIs are broken?  Supplying code would help us help you diagnose this issue.
(3,524 Views)
(3,514 Views)
Thanks for attaching your program.  I'm having a lot of trouble running it -- LabVIEW doesn't seem to know how to process a file with the .jpg extension.  Could you please attach a file with the extension .vi, which is what LabVIEW expects?  This way, I'll know that I'm working on exactly the same code that you describe ...
Bob Schor
(3,509 Views)
haha..very funny 🙂
(3,492 Views)
