Having issues in find the exact location of the peaks.
@HassanIqbal wrote:
I was making the mistake you mentioned at the very end of your comment. Thank you very much for your detailed help.
Regards
Hassan
You're very welcome.
If you've managed to solve your problem, maybe you can help keep the forum tidy/easy to use/read by marking a solution. I'd suggest GerdW's message (#7 in this thread).
You can also give kudos to posts that helped you (or any other decision process you like) by clicking the stars.
Neither of these is required but the solutions help to mark which threads are "finished", more or less, and kudos thank others for their help, etc.
GCentral
Message 11 of 11
(233 Views)
