Having issues with Linx and Arduino connection
I'm currently having issues with getting an Arduino Leonardo to properly connect and function via the Linx control. (File: "DOESNT WORK...") Sometimes upon running the program the Linx spits out an 5003 error which, as far as I can tell, is just a communication failure. Other times, the link enters the while loop without issue, but then boolean controls that follow in the Linx chain have incredibly slow response times (10-20s, if not more). The NI DAQ that also exists in this vi often times out and can't keep with up the software, causing a failure of a different kind but which is surely related. I've tried various combinations of acquisition mode, # of samples to read, and sampling rate, to try and ease the load on it but nothing has helped.
I've tried several time to follow the Tools -> MakerHub -> Linx -> Linx Firmware Wizard and re-upload the Arduino firmware, but this also leads to a communication failure and I don't think it helps anything.
I have another vi ("WORKS...) that contains only the Linx chain (reading off the same COM port) and DAQ assistant (and associated items) that works perfectly, with no Arduino connection or DAQ issues to speak of and very quick boolean control response time.
Why would the other vi work without issue but when I try to run this one it rarely completes the connection, let alone functions as a vi properly?
Also I'm rather new to LV and almost certainly haven't done everything in this vi as efficiently and cleanly as possible, so if you see something blatant that could be better please point it out. However, the Linx and DAQ are my main concerns.
Thanks in advance,
Drake
Message 1 of 1
(1,808 Views)
