Having problem in bandpassfilters while constructing my VI for QRS detector
Hi
This is my VI with input signal.I am having some problem with bandpass filter. I have tried everything but not able to solve the problem.
Jaini
(2,694 Views)
You did not put data file Jaini-L05.lvm, can not run the VI.
(2,687 Views)
 i can give you some other file to run the vi, I have fs=200samples/ sec and i am keeping higher cut off fh=100Hz and fl=50 Hz  and it shows me error regarding nyquist thyrm.
(2,671 Views)
Read this http://en.wikipedia.org/wiki/Nyquist%E2%80%93Shannon_sampling_theorem. It may explain your problem Smiley Very Happy. You will also find this topic covered in many tech notes at www.ni.com. Anyway I guess you need a bandwidth up to say 300 Hz. To get a fair signal reproduction I recommend sampling with at least 3 Khz (10 times your upper bandwidth).
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,668 Views)
Sorry my adress got messed up i ment http://en.wikipedia.org/wiki/Nyquist–Shannon_sampling_theorem
(2,667 Views)
