Having problem with discontinuity in the waveform
Hi Experts,
I am trying to build a multifunction vi that is able to generate analog waveforms and read them simultaneously using USB-6251 and Signal Conditioning Connector Block Model SC-2345. I plan to add a signal from the sensor to the waveform in the future but that is not the case now. However, when I run the program, it turns out to a small discontinuity in the waveforms which I really have no idea how to fix it. And it is quite unacceptable since it affects the shape of the waveform and its frequency. I attached the file. Any suggestions would be greatly appreciated.
Sorry if my English causes you problems. Thanks in Advance.
Nattapat Thanesvorakul
Student
(2,975 Views)
Please... Anybody...
(2,901 Views)
Accepted by topic author Kun_Nattapat
There are a couple issues that could be causing this. First, you are resetting the function generator each time and you are not set for continuous generation.
(2,885 Views)
Thank you very much for your reply, Dennis.
The program seems okay now.
(2,875 Views)
